ONLYOFFICE connector v6.3.0 for Confluence: .vsdx, .md, .odg files & security updates
The latest version of the ONLYOFFICE connector for Confluence is now available on the Atlassian Marketplace. Enjoy enhanced file format support, a new option to disable macros, and improved compatibility with the latest Confluence releases.
Support for further file formats
You can now work with a wider range of files without relying on third-party converters. Newly supported formats include:
- Open diagrams for viewing: .vsdx, .vssx, .vstx, .vsdm, .vssm, .vstm.
- Open Markdown (.md) files for viewing.
- Open OpenDocument Graphic (.odg) files for viewing.
- Open .xlsb files for editing.
Navigate to your Attachments, locate the desired file or upload a new one, and select the View in ONLYOFFICE option.
The file will open in a new tab using the appropriate editor:
By selecting the Convert using ONLYOFFICE option, the file will be converted to OOXML formats (DOCX, XLSX, PPTX) for seamless editing.
Disabling macros
Disable running macros in documents to restrict access to specific services and limit task automation within the editors for other users.
Where to find (for admins): Confluence administration -> Manage apps -> ONLYOFFICE app for Confluence -> Configure -> Security -> Run document macros
Other improvements
- Security fix: updated dependencies with vulnerabilities (CVE-2025-27820)
- Compatibility with Confluence 9.5.2
Refer to the full changelog on GitHub.
Get the updated connector
Download the latest version of the ONLYOFFICE connector for Confluence from the Atlassian Marketplace and enjoy improved performance, wider format compatibility, and a more secure document editing experience inside your Confluence environment:
Frequently asked questions (FAQ)
Q: Is the ONLYOFFICE connector for Confluence free?
A: Yes, the connector is absolutely free. You can install it from the Atlassian Marketplace.
Q: Do I need to install ONLYOFFICE Docs to use the integration?
A: Yes, you need. You can deploy the editors on-premises or sign up for the cloud version.
Q: Is ONLYOFFICE compatible with Confluence Cloud, Server, and Data Center?
A: Yes, the connector is available for all three hosting options.
Q: Can I use ONLYOFFICE Docs with other Atlassian products?
A: Yes, ONLYOFFICE also integrates with Jira.
Useful links
Get ONLYOFFICE Docs for Confluence: Enterprise / Community / Cloud
ONLYOFFICE & Confluence integration
