TeamLab: Benefit from Web Integration with REST API
Dear tech-savvy users!
We are glad to inform you that TeamLab launches the application programming interface (API).
From now on you will be able to:
- import and export necessary data,
- build applications on top of TeamLab
- integrate TeamLab tools into existing programs and services
- create javascript widgets.
Implemented as the representational state transfer (REST) architecture over the HTTP protocol, TeamLab API processes the standard requests with the GET/POST/PUT/DELETE commands and supports JSON/XML data formats. All the module elements, like posts or comments, have their own URLs and can be requested separately allowing users a flexible choice of features for integration depending on their needs.
Along with that the quick access to larger amounts of data is also possible. If an application needs the ability to retrieve data and make changes to several objects at once, TeamLab API provides a batching option to submit instructions for several operations in a single HTTP request.
To get use of TeamLab API, please go to http://api.teamlab.com
