How BidFix embedded ONLYOFFICE Docs to power faster, compliant tender responses
Summary
BidFix embedded ONLYOFFICE Docs to enhance the efficiency and compliance of tender responses by providing a seamless editing experience directly within their platform. This integration allows users to edit Word, Excel, and PDF documents without leaving the application, significantly reducing response times by 50 to 80 percent while ensuring sensitive data remains secure and compliant with EU regulations.
- ONLYOFFICE Docs enables in-app document editing.
- Users can edit multiple document formats seamlessly.
- Integration reduces tender response times significantly.
- Data remains secure within BidFix's EU infrastructure.
- Format fidelity ensures no layout issues arise.
Public procurement is one of the largest and most document-heavy markets in the world. Yet the way companies respond to tenders remains stubbornly manual. Teams have to track relevant opportunities across more than 100 fragmented procurement portals, judge whether each bid is worth pursuing, and complete dozens of complex documents under tight deadlines.
That is the problem BidFix set out to solve. Developed by Fix Solutions GmbH in Germany, BidFix is an AI platform for public tenders (RFPs) across the DACH region and the wider EU. It continuously scans 100+ procurement portals and uses a hybrid mix of AI, semantic, and keyword search to surface tenders that match a company’s profile. It then extracts eligibility and award criteria for a quick Bid/No-Bid decision, and supports teams as they draft and complete their response with an AI copilot that understands both the tender and the company’s knowledge base.
The results speak for themselves: customers cut the time spent on tender responses by 50 to 80 percent. More than 1,000 companies rely on BidFix today, from SMEs to enterprises such as JobRad, MR Datentechnik, and Synaforce.
A core part of that experience runs on ONLYOFFICE Docs. Here’s how the BidFix team built it.
The challenge: editing at the heart of every tender
Document editing isn’t a side feature for BidFix, it’s central to what users do every day. A single tender response can involve dozens of Word, Excel, and PDF files, each with its own formatting and requirements.
The old way of handling this would have been clunky: download a file, open it in a desktop suite, edit it, then re-upload it. That kind of back-and-forth slows teams down and breaks the flow of work. BidFix needed something better, namely best-in-class editors that could live directly inside their web application.
During their evaluation of embeddable editors, the team looked closely at the available options. ONLYOFFICE Docs stood out as the most complete and standards-compliant choice, backed by a robust developer API.
Why ONLYOFFICE: three decisive factors
The BidFix team weighed the common alternatives, including browser-based viewers, other embedded editor SDKs, and cloud office APIs. Most fell short on at least one critical requirement. Three factors made ONLYOFFICE the clear winner.
- Format fidelity. Public-sector documents come packed with complex Word and Excel formatting. ONLYOFFICE processes OOXML natively, so the contracting authority sees exactly what the user edited. It means no surprises and no broken layouts. For documents that go to government bodies, that reliability is non-negotiable.
- Easy API integration. The Docs API made it straightforward to embed the editors directly into the platform and wire them into the BidAI copilot. The developer experience kept the integration simple rather than fighting it at every step.
- Self-hosted EU infrastructure. This was the most important factor of all. ONLYOFFICE can run fully self-hosted on BidFix’s own EU infrastructure, which matters enormously given the sensitive procurement data involved.
BidFix is ISO 27001 certified, fully GDPR compliant, hosted in Germany on EU servers, and protected with AES-256 encryption. Because ONLYOFFICE sits inside their own environment, documents never leave their controlled infrastructure to be edited. Sensitive tender data stays within their compliance perimeter end to end, exactly what public-sector and enterprise customers demand.
Many alternatives lacked the required format fidelity, couldn’t be self-hosted within the EU, or didn’t offer the level of data control BidFix needed. ONLYOFFICE checked every box.
The integration: one seamless editing experience
BidFix embeds the ONLYOFFICE editors directly inside the web application through the Docs API. Users can open, edit, complete, and finalize tender documents in Word, Excel, and PDF without ever leaving the platform.
BidFix & ONLYOFFICE integration (text document)
BidFix & ONLYOFFICE integration (spreadsheet)
BidFix & ONLYOFFICE integration (PDF)
The real differentiator is how the editing experience connects to BidFix’s “BidAI” copilot, which works right alongside the embedded editor. In context, the copilot can:
- Transfer pricing from past projects straight into an Excel cost sheet
- Draft concept text inside a Word document
- Pre-fill questionnaires using the company knowledge base
Instead of a fragmented series of upload and download steps, users get a single, fluid workflow. The integration has proven stable, and the formatting holds up reliably across documents.
The results: faster responses, full control
The embedded editing experience is a core reason BidFix customers reduce the time spent on tender responses by 50 to 80 percent. Rather than shuffling documents between separate tools, teams find, analyze, edit, and submit everything in one place.
Just as important, it strengthens the trustworthiness of the product. Because the entire process takes place within BidFix’s secure, EU-hosted environment, customers can be confident their sensitive data stays protected from start to finish.
When asked how likely they’d be to recommend ONLYOFFICE, the answer was clear: very likely. For any product that needs reliable, format-faithful document editing, especially where self-hosting and data control matter, ONLYOFFICE is a strong choice, and the Docs API makes the integration approachable.
Alexander Kohler, Founder & CEO at BidFix:
Editing documents is at the heart of every tender response. ONLYOFFICE enabled us to embed best-in-class, format-faithful editors directly into BidFix and to operate them fully self-hosted within the EU, so that our users can find, analyze and submit tenders in one secure environment while our AI copilot works directly inside the document.
Conclusion
BidFix shows what’s possible when powerful document editing meets smart automation in a secure, compliant setup. By embedding ONLYOFFICE Docs through the API and pairing it with their BidAI copilot, the team turned a slow, fragmented process into a single seamless experience, and helped over 1,000 companies respond to public tenders far faster than before.
If you’re building a product that needs reliable, format-faithful editing with full control over your data, ONLYOFFICE offers a developer-friendly path to get there. Explore the ONLYOFFICE Docs Developer to see how it could fit into your own platform.
