New ImageEditor plugin for ONLYOFFICE DocSpace: view and edit images
The new ImageEditor plugin is now available in ONLYOFFICE DocSpace, giving you an easy way to view and edit images without downloading them to your device. Crop, resize, annotate, add shapes or text — all directly inside your workspace.
About the plugin
The ImageEditor plugin adds a built-in image editing tool to DocSpace, allowing users to adjust visuals and update graphic assets in shared rooms quickly.
Key features:
- Open and edit images directly in DocSpace
- Resize, crop, flip, and rotate images
- Draw with a freehand tool
- Add shapes, icons, and text
- Apply masks
- Save changes as a new version of the file
- Work with a wide range of image formats
Supported formats: .jpg, .jpeg, .png, .gif, .webp, .svg, .bmp, .tiff, .ico
This plugin is ideal for quick edits, small corrections, or preparing visuals for documents and collaboration — all without switching between apps.
How to edit images with the ImageEditor plugin
To start editing, right-click any supported image file in your DocSpace → Edit Image.
An editor window will open with a right-side toolbar offering all available tools:
- Resize
- Crop
- Flip
- Rotate
- Draw
- Shape
- Icon
- Text
- Mask
- Filter
After you have made changes to each section, click Apply to save them.
In the left-side toolbar, you can also zoom in and out, view the history of changes, undo or redo the action, or delete all changes with one click.
To change the image, click Load and choose a new one from your device. To save the current image, use the Download button.
When you’re done, click Save and Exit. DocSpace will apply your changes and create a new file version.
Opening the file in the standard DocSpace image viewer will display the latest version.
To open previous versions, go to Properties → Show version history.
How to configure
The plugin is enabled by default. If you previously disabled plugins, you can re-enable them:
Settings → Integration → Plugins → ImageEditor
Try in ONLYOFFICE DocSpace
Sign up for free and start using DocSpace with built-in plugins today to store and edit images in your collaborative file space:
User feedback and support
If you have ideas, bug reports, or feature suggestions, join the discussion in the ONLYOFFICE Community or share your proposals on our feedback platform.
Useful links
ImageEditor plugin repository on GitHub
New plugins for DocSpace: CodeMirror / ZipArchives
