100 Raw Facts about TeamLab Office Edition. Part II.
Some more minor but important facts on our global release.
Final ones
Thanks to the liquid layout of the user interface, the portal content will be displayed correctly on any screens.
With more convenient, tree-folder navigation you will always know where you are at the portal at the moment, get back easily to any of the previous elements or find a desired feature.
More filter presets to ease your search. For example, under the Projects section in the Projects module you will be able to make use of the “My”, “Projects I follow”, “Active” presets.
Less Clicking
More docs with less clicks! The embedded file converter makes a batch upload of documents possible even with different formats.
Fast access to the most basic operations with the Create New… button available from every page in the Documents, Projects and Community modules.
More and More
A nice benefit mostly demanded by small teams and non-profit organizations – an option for members to be a part of several groups at a time.
Feed as a single notification center: learn what’s new in all the modules of the portal at a glance.
Even more filters for speedy content search.
If you’re eager to make use of the new TeamLab options and enjoy the described benefits, switch to new version 7.0: go to your portal Settings, scroll down till the Portal Version and choose 7.0, beta.
