How to analyze PDF form documents with ONLYOFFICE macro
In today’s fast-paced digital environment, writers, editors, and content creators often struggle to gain meaningful insights about their documents. Understanding metrics like readability, word frequency, and structural balance can significantly improve document quality, yet manual analysis is time-consuming and inconsistent. In this blog post, we’ll show you how to craft a powerful ONLYOFFICE macro that automatically analyzes your documents and generates comprehensive reports.
Building the document analysis macro
Let’s break down our macro into functional components and explain how each part works.
Setting up the main function
The core of our macro is the analyzeDocument() function, which orchestrates the entire analysis process:
function analyzeDocument() {
try {
// Get document and all text
var allText = "";
var paragraphs = oDocument.GetAllParagraphs();
// Check if document is empty
if (paragraphs.length === 0) {
console.log("Warning: Document is empty or no paragraphs found for analysis.");
return;
// Collect all text
paragraphs.forEach(function(paragraph) {
allText += paragraph.GetText() + " ";
// Perform analyses
var stats = calculateBasicStats(allText, paragraphs);
var advancedStats = calculateAdvancedStats(allText, stats);
var commonWords = findCommonWords(allText, 10);
// Create report
createAndAddReport(oDocument, stats, advancedStats, commonWords);
// Log success
console.log("Success: Document analysis completed. Report added to the end of the document.");
} catch (error) {
console.log("Error: " + error.message);
This function first collects all text from the document, then passes it to specialized analysis functions, and finally creates a report. The try-catch block ensures the macro gracefully handles any errors.
Calculating basic statistics
The calculateBasicStats() function processes the text to extract fundamental metrics:
function calculateBasicStats(text, paragraphs) {
// Word count
var words = text.split(/\s+/).filter(function(word) {
return word.length > 0;
var wordCount = words.length;
// Sentence count
var sentences = text.split(/[.!?]+/).filter(function(sentence) {
return sentence.trim().length > 0;
var sentenceCount = sentences.length;
// Paragraph count
var paragraphCount = paragraphs.length;
// Character count
var charCountWithSpaces = text.length;
var charCountWithoutSpaces = text.replace(/\s+/g, "").length;
// Line count (approximate)
var lineCount = Math.ceil(charCountWithSpaces / 70);
return {
wordCount: wordCount,
sentenceCount: sentenceCount,
paragraphCount: paragraphCount,
charCountWithSpaces: charCountWithSpaces,
charCountWithoutSpaces: charCountWithoutSpaces,
lineCount: lineCount,
words: words,
sentences: sentences
This function splits the text into words and sentences, counts paragraphs, and calculates character and line counts.
Performing advanced analysis
For deeper insights, the calculateAdvancedStats() function computes more sophisticated metrics:
function calculateAdvancedStats(text, basicStats) {
// Average sentence length
var avgWordsPerSentence = basicStats.wordCount / Math.max(1, basicStats.sentenceCount);
// Average paragraph length
var avgWordsPerParagraph = basicStats.wordCount / Math.max(1, basicStats.paragraphCount);
// Average word length
var totalWordLength = basicStats.words.reduce(function(sum, word) {
return sum + word.length;
}, 0);
var avgWordLength = totalWordLength / Math.max(1, basicStats.wordCount);
// Readability score (simplified Flesch-Kincaid)
var readabilityScore = 206.835 - 1.015 * avgWordsPerSentence - 84.6 * (totalWordLength / basicStats.wordCount);
// Estimated reading time
var readingTimeMinutes = Math.ceil(basicStats.wordCount / 200);
return {
avgWordsPerSentence: avgWordsPerSentence,
avgWordsPerParagraph: avgWordsPerParagraph,
avgWordLength: avgWordLength,
readabilityScore: readabilityScore,
readingTimeMinutes: readingTimeMinutes
This calculates average sentence and paragraph lengths, readability scores, and estimated reading time.
Analyzing word frequency
The findCommonWords() function identifies the most frequently used words:
function findCommonWords(text, limit) {
// Clean text and convert to lowercase
var cleanText = text.toLowerCase().replace(/[.,\/#!$%\^&\*;:{}=\-_`~()]/g, "");
// Split into words
var words = cleanText.split(/\s+/).filter(function(word) {
return word.length > 3;
// Calculate word frequencies
var wordFrequency = {};
words.forEach(function(word) {
wordFrequency[word] = (wordFrequency[word] || 0) + 1;
// Filter stop words
var stopWords = ["this", "that", "with", "from", "have", "been"];
stopWords.forEach(function(stopWord) {
delete wordFrequency[stopWord];
// Sort by frequency
var sortedWords = Object.keys(wordFrequency).sort(function(a, b) {
return wordFrequency[b] - wordFrequency[a];
// Return top N words
return sortedWords.slice(0, limit).map(function(word) {
return { word: word, frequency: wordFrequency[word] };
// Split into words
This function removes punctuation, filters common filler words, and returns the most frequently used words in the document.
Generating the report
Finally, the createAndAddReport() function compiles and formats all the analysis results:
function createAndAddReport(oDocument, basicStats, advancedStats, commonWords) {
// Add new page
oParagraph.AddPageBreak();
oDocument.AddElement(oDocument.GetElementsCount(), oParagraph);
// Add title
var oHeading = Api.CreateParagraph();
oHeading.AddText("DOCUMENT ANALYSIS REPORT");
oDocument.AddElement(oDocument.GetElementsCount(), oHeading);
// Add basic statistics section
var oSubHeading = Api.CreateParagraph();
oSubHeading.AddText("BASIC STATISTICS");
oDocument.AddElement(oDocument.GetElementsCount(), oSubHeading);
// Add statistics content
// ... (code that adds individual statistics)
// Add advanced analysis section
// ... (code that adds advanced metrics)
// Add word frequency section
// ... (code that adds word frequency list)
// Add footer
var oFootnotePara = Api.CreateParagraph();
oFootnotePara.AddText("This report was generated by OnlyOffice Document Statistics and Analysis Tool on " +
new Date().toLocaleString() + ".");
oDocument.AddElement(oDocument.GetElementsCount(), oFootnotePara);
This function creates a structured report at the end of the document with all the analysis results.
Complete macro code
Here’s the complete macro code that you can copy and use:
(function() {
// Main function - starts all operations
try {
var allText = "";
return;
// Collect all text
// Calculate basic statistics
// Perform advanced analysis
// Find most common words
// Create and add report to the document
// Inform user
} catch (error) {
console.log("Error: An error occurred during processing: " + error.message);
// Word count
// Sentence count
// Paragraph count
// Character count (with and without spaces)
var lineCount = Math.ceil(charCountWithSpaces / 70); // Approximately 70 characters/line
return {
words: words,
// Calculate advanced statistics
// Average sentence length (in words)
// Average paragraph length (in words)
// Average word length (in characters)
}, 0);
var readabilityScore = 206.835 - 1.015 * (basicStats.wordCount / Math.max(1, basicStats.sentenceCount)) - 84.6 * (totalWordLength / Math.max(1, basicStats.wordCount));
// Estimated reading time (minutes)
var readingTimeMinutes = Math.ceil(basicStats.wordCount / 200); // Average reading speed 200 words/minute
return {
// Split into words
return word.length > 3; // Filter out very short words
if (wordFrequency[word]) {
wordFrequency[word]++;
} else {
wordFrequency[word] = 1;
// Filter stop words (common English words)
var stopWords = ["this", "that", "these", "those", "with", "from", "have", "been", "were", "they", "their", "what", "when", "where", "which", "there", "will", "would", "could", "should", "about", "also"];
if (wordFrequency[stopWord]) {
// Take top N words
var topWords = sortedWords.slice(0, limit);
// Return results as word-frequency pairs
return topWords.map(function(word) {
return {
word: word,
// Create and add report to document
// Add new page
// Main title - highlighting in capital letters
// Subheading - in capital letters
var oStatsPara = Api.CreateParagraph();
oStatsPara.AddText("• Word Count: " + basicStats.wordCount);
oDocument.AddElement(oDocument.GetElementsCount(), oStatsPara);
oStatsPara.AddText("• Sentence Count: " + basicStats.sentenceCount);
oStatsPara.AddText("• Paragraph Count: " + basicStats.paragraphCount);
oStatsPara.AddText("• Character Count (with spaces): " + basicStats.charCountWithSpaces);
oStatsPara.AddText("• Character Count (without spaces): " + basicStats.charCountWithoutSpaces);
oStatsPara.AddText("• Estimated Line Count: " + basicStats.lineCount);
// Advanced analysis title
oSubHeading.AddText("ADVANCED ANALYSIS");
// Add advanced analysis results
oStatsPara.AddText("• Average Sentence Length: " + advancedStats.avgWordsPerSentence.toFixed(2) + " words");
oStatsPara.AddText("• Average Paragraph Length: " + advancedStats.avgWordsPerParagraph.toFixed(2) + " words");
oStatsPara.AddText("• Average Word Length: " + advancedStats.avgWordLength.toFixed(2) + " characters");
oStatsPara.AddText("• Readability Score: " + advancedStats.readabilityScore.toFixed(2));
oStatsPara.AddText("• Estimated Reading Time: " + advancedStats.readingTimeMinutes + " minutes");
// Common words title
oSubHeading.AddText("MOST FREQUENTLY USED WORDS");
// We'll create a simple list instead of a table
if (commonWords.length > 0) {
for (var i = 0; i < commonWords.length; i++) {
var oWordPara = Api.CreateParagraph();
oWordPara.AddText((i + 1) + ". " + commonWords[i].word + " (" + commonWords[i].frequency + " times)");
oDocument.AddElement(oDocument.GetElementsCount(), oWordPara);
} else {
var oNoneFoundPara = Api.CreateParagraph();
oNoneFoundPara.AddText("No frequently used words found.");
oDocument.AddElement(oDocument.GetElementsCount(), oNoneFoundPara);
// Footer note
// Run the macro
analyzeDocument();
To use this macro in ONLYOFFICE
- Open your document in ONLYOFFICE
- Navigate to the View tab and select Macros
- Create a new macro and paste the code
- Run the macro
- A detailed analysis report will be added to the end of your document
Now let’s run our macro and see how it works!
This macro is a valuable tool for professionals looking to automate text analysis and documentation processes in a modern office environment. We hope it will be a useful addition to your work toolkit.
We encourage you to explore the ONLYOFFICE API documentation to create your own custom macros or enhance this one. If you have ideas for improvements or suggestions for new macros, please don’t hesitate to contact us. Your feedback helps us continue developing tools that make document creation and editing more efficient.
About the author
